FS: 2000 Honda Prelude Base Manual - clean, second owner $6500 OBO
2000 Honda Prelude Base JHMBB6140YC000984
193k miles
5-speed manual
Premium White exterior with black interior
No accidents or rust
Non-smoker
Largely original
Long term original ownership (2000-2019), I’m the second owner
Lifetime North Carolina car (RTP area)
Well maintained with thorough service history
Window sticker, two keys and remotes, one valet key, one emergency key
Recent maintenance and upgrades in the past six months:
Enkei 17” RP02 wheels in like new condition with new Pirelli P-Zero Nero GT summer tires 215/40R17. Lighter than OEM wheels, Road Force balanced, period correct. Less than 100 miles of use.
16” Honda “blades” with Continental ExtremeContact DWS 09 sport all-seasons 205/50R16. 20k miles on tires, 6-7/32nds left.
New Tein Flex Z coilovers (10k front/6k rear, adjustable damping)
New ST Suspension rear anti-sway bar
New rear toe arms
New rear upper control arms
New rear brake rotors
New rear Stoptech Sport pads
New rear Centric remanufactured calipers
DOT4 Brake fluid flush
New Honda spark plugs
Valve adjustment
New intake air filter
Oil/filter change
New PCV valve/grommet
New oil cooler o-ring
New valve cover gaskets
Nicer valve cover
New tail light gaskets
New roof moldings
New cabin air filters
Warm LED cabin and license plate bulbs for a little more brightness
ProClip magnetic cell phone mount specific for Honda Prelude, removable without damage to interior
Timing belt, water pump, tensioners are up to date, last done 06/16 @ 159k.
More about the car:
I bought the car in 2019 from the original owner, who used it as his commuter car from Chapel Hill to RTP for 19 years. The car has been well taken care of and looks and drives great.
Exterior and interior are remarkably clean. Paint is in excellent overall condition. A few small dings and scrapes and some spots of touch-up paint. It is not perfect but looks really great for the age and mileage -- you’ll be impressed. All electronics work such as sunroof, stereo, cruise control, power windows and locks. Cold AC, hot heat.
The suspension was almost completely original when I got the car. Only the front shocks had ever been replaced. I replaced some worn parts and It’s a ton better now. There is more work to do if you’re looking for projects, but it’s fun to drive and reliable as-is.
H-series engines are known for consuming oil. The original owner said he added one quart every few tanks of gas. I’ve driven the car 1,200 miles and done an oil change part way through, so I’m not totally sure about the oil usage but it has not been a problem for me. Engine, transmission, clutch, are original.
The previous owner had most of the notorious leaky seals replaced on the engine, so it’s pretty dry and looks good. The only leak I’ve found is likely from the rear main seal, which is easy to address when the car eventually has a clutch job. It drips a couple drops of oil per week from around the transmission bell housing.
Why I’m selling:
I purchased this car on a whim and have really enjoyed going through it and driving my kids around in it. I’ve driven it around town regularly and taken two 300mi road trips and it has been comfortable and reliable. I’ve found the car very easy to work on thanks to high build quality, simplicity, and a PDF of the factory service manual. However, my family would like to consolidate down to a single car for now. No hurry to sell.
