92 Civic Auto Trans issue
Old Mar 3, 2020 | 05:09 AM
Boxer Rebe11ion's Avatar
Default 92 Civic Auto Trans issue
I drive a 92 civic lx with a auto trans it has about 200000 miles on it and as I was driving home yesterday my car kept going into neutral so I limped it home found out the trans fluid was burnt so I changed it out and now I can manually shift the gears while driving but it won’t go above 45mph and when the car is in reverse it shakes and barely moves. And finally when I put it in park after driving it makes a short grinding noise like half a second long. Also the check engine light isn’t throwing any codes
Old Mar 3, 2020 | 05:27 AM
muellersfan's Avatar
Default Re: 92 Civic Auto Trans issue
Doesn't sound good.
Start by checking the shift cable adjustment.
What ATF did you add to the transmission?
Also try 3-5 additional ATF drain-refill cycles. After each drain-refill, SLOWLY move the shifter through all of the gears multiple times with engine idling to maximize ATF circulation through the transmission.
Good luck.
92civichelp
Jan 1, 2013 02:30 AM
micah92integra
Jul 26, 2011 06:14 AM
tiNnNy
Transmission & Drivetrain
Oct 10, 2009 06:16 PM
