D16Z6 Turbocharger Oil Pressure Verification Question
Old Mar 2, 2020 | 12:29 PM
bldzrr's Avatar
Default D16Z6 Turbocharger Oil Pressure Verification Question
Freshly built d16z6.
Autometer oil pressure gauge w/ nylon tubing fed from oil sandwhich plate
gt3582 fed from -4an coming off sandwhich plate
Cold idle 85-90psi
Warm idle 18-20psi
I haven't drove the car yet but are these numbers good for oil pressure at idle? 800-1000rpm
Old Mar 2, 2020 | 01:32 PM
Txdragon's Avatar
Default re: D16Z6 Turbocharger Oil Pressure Verification Question
What oil weight and what bearing clearances?
Old Mar 2, 2020 | 01:41 PM
bldzrr's Avatar
Running 5w30 non synthetic right now for break in and honestly I can't remember my clearances but it's stock z6 crank and std size ACL race bearings
Old Mar 2, 2020 | 01:59 PM
Txdragon's Avatar
so clearances should be between .0015 and .0018
Also.. where is your pressure while driving?
Old Mar 2, 2020 | 02:15 PM
bldzrr's Avatar
Yes if I remember correctly I was getting 0.0016-0.0017 across for clearances and I haven't drove the car yet. I'm in Canada so waiting for all the salt/snow to clear lol
Old Mar 2, 2020 | 02:20 PM
Txdragon's Avatar
Ok, now we're getting some data! The pressure cold is a bit on the high side but I can imagine Canadian wintertime can leave oil like molasses. Lol! Warm idle looks good, and should see around 75 or so at 3k rpm, usually around 90ish at WOT.
turboLScrx's Avatar
25 Year Member
Loved
Community Favorite
Looks pretty normal to me , if it gets much lower I would use a thicker oil. I suggest 10w-30 usually on a factory clearance motor unless your in a very hot environment
Old Mar 2, 2020 | 02:37 PM
DaX's Avatar
DaX
Loved
Community Favorite
My cold idle is similar to yours (also turbo D16Z6). My fully warmed idle is around 15 psi in the cooler months. Last summer was hot (southern US) and my fully warmed idle would be down as low as 8 psi sometimes. I am currently running 10W-30 full synthetic and my bearing clearances are around 0.0016". I may try some 20W-50 in the heat of the summer to see if it improves my warm idle oil pressure.
Old Mar 2, 2020 | 04:28 PM
bldzrr's Avatar
yeah it's still below 0 here and also I did shim the pump slightly but not sure if that effects cold or warm idle.
Old Mar 2, 2020 | 04:31 PM
Txdragon's Avatar
It affects all operating pressure. It puts additional "preload" pressure on the pressure relief valve spring, causing it to open up later.
Old Mar 2, 2020 | 04:47 PM
bldzrr's Avatar
so I guess that may be my reason for higher pressure on cold idle. Thanks for all the help, just wanted to make sure my pressure was good!
jarven093
Apr 26, 2007 06:26 PM
cibola
11
Nov 22, 2006 05:57 AM
O16581724 5 2 5
Aug 12, 2005 10:55 PM
