DIY Bluetooth module
Old Mar 1, 2020 | 12:52 PM
sacred420's Avatar
Default DIY Bluetooth module
Hi
m new on this forum I am trying to install blue tooth to my data logger on my PO6 4 pin connector can someone guide me if it will work or no cause i have red people using Nokia data cable on that. Plus if someone guide me the output of data logger pins i am attaching module pictures and i have also found USB cable which can be used for com port i need advise.....
Blue tooth module with pins location
Data cable
Data cable wiring diagram
Old Mar 2, 2020 | 01:44 PM
muellersfan's Avatar
Default Re: DIY Bluetooth module
Are you trying to figure out which pins go to which wires?
And at first glance, the cable and board seem to be a mismatch because the board lacks an RXD pin (unless the skewed view is an optical illusion).
Old Mar 2, 2020 | 03:13 PM
Relic1's Avatar
it's the angle, EN does not have any solder on the pad, but the middle four do.
OP:
that module may work... depending on how the the device works, some require a connect signal to connect to the receiver first... the ECU is not going to do that.
I found it very difficult to dig enough info to make sure any of them were going to work.... I ended up buying the moates version (cause I knew it wold work) but it's backordered.... http://www.moates.net/neptunedemon-b....html?cPath=69
Old Mar 2, 2020 | 08:48 PM
sacred420's Avatar
yeh man m trying to figure out pins on ECU man these are two different things here is the case i want cable and Bluetooth module both plugged in to PO6 ECU. Just want to confirm data logger output from ECU uni
Old Mar 2, 2020 | 08:54 PM
sacred420's Avatar
OP:
I found it very difficult to dig enough info to make sure any of them were going to work.... I ended up buying the moates version (cause I knew it wold work) but it's backordered.... Neptune/Demon Bluetooth Module Add-on: BACKORDERED [BT_D2] - $40.00 : Moates.Net
man this thing is costing me only 2$ Both cable and Bluetooth module so need to figure out only output from ECU i.e data log port
Old Mar 3, 2020 | 08:19 AM
sacred420's Avatar
OP:
man can u share diagram ??? Please
Old Mar 4, 2020 | 10:14 AM
Relic1's Avatar
so you are looking for the CN2 pinout?
from pgmfi.org:
  • 1: GND
  • 2: RX (send Data from the PC to the ECU)
  • 3: +5 Volt
  • 4: TX (send Data from ECU to the PC)
  • 5: N.C. (not connected)
cua0
May 10, 2007 05:16 PM
memorybox
Dec 19, 2006 08:03 AM
crxisty
Dec 5, 2004 06:26 AM
