D15B2 No start after trans swap
Hey guys. Going crazy here trying to get this car to run again. I have scoured this site and others reading almost every post regarding a no start and haven't been able to pin anything down.
Bought a 91 DX Wagon with the D15b2 a few weeks ago running and mostly driving. Trans was basically shot so picked up a new to me trans and put it and a new clutch in. Got everything put back together aaaaaand cranks all day but wont start. I drove this thing home and up into my garage, swapped the trans and now nothing. I've gotten a few little sputters and one backfire.
What I've checked:
I have fuel. I can smell it while cranking, pump primes with key turn etc. Cyl 1 and 2 plugs seem to get soaked with fuel but 3 and 4 don't, not sure if that matters. Though I do think at once point I ran it out or almost did. Added a few gallons
I have spark, albeit a little weak but it's there (orange-ish color)
Replaced dizzy (needed a new one anyway), no change
Checked, re-checked, and triple checked plug wire order
Checked all fuses, under dash and hood
ECU seems to work, flashes once with a key turn then flashes me a code 10
Checked cam timing, I think this is good? 2 marks and the UP mark are parallel with the head with Cyl 1 at tdc
Grounds were a little iffy so added one from battery to body to trans, cleaned up thermostat ground, and added one from valve cover to body
A few other things to note, I got a 'new' identical harness to replace the kind of hacked one that was in there. Thought maybe that would be the problem so switched back to old one, nope. Did the same thing with the dizzy.
Car got a little hot at idle once because the fan is hotwired to a switch that I forgot to flip. Steaming from under hood, it was running maybe 2 minutes tops at this time
Thanks for any help, I'm going insane trying to figure this out. Just wanna get it back together, off jack stands and take it for a ride but with all the gears this time. lol
What I've checked:
Checked both coils today. Been inside for 24+ hours at around 70. New coil came back with 0.9-1, and around 11k secondary. Old one same primary and around 12k secondary. Also did a compression test over the weekend:
1- 110
2- 140
3-150
4-170
Thoughts on where to go from here? Guessing I need a new coil based on the results
1- 110
2- 140
3-150
4-170
1- 110
2- 140
3-150
4-170
1- 110
2- 140
3-150
4-170
IAT has been verified as plugged in.
Definitely losing coolant. Boiled over and steaming from under hood, because I forgot to turn the hotwired fan on while idling it for a few mins. Seems its pretty quick to overheat but not sure 100% because temp gauge doesn't work. Currently not seeing anything in rad and hoses feel pretty empty
Pretty sure the cam timing is good. At TDC on #1, the two marks seem to line up with the head, as well as the up mark facing up
That could be it because o2 currently isn't hooked up. Old harness the connector was cut, new harness has it but there a 4 wire sensor in the manifold instead of a 1 wire
Dual point injectors have issues with something in modern fuel mixtures. They start to leak internally, and a few days of sitting around can wash out the rings.
Pull the plugs and let the chambers air out. A few hours above freezing is usually enough. Add some oil to help reseat the rings.
I did none of that during the compression test, I will redo that tonight. How do I disable the injectors?
Update, scelestus must have been onto something. Went out the other day, put it all back together and it actually fired! Also the trans and clutch work great which is a big weight off my shoulders knowing I installed everything right.
Put my "new" clean wiring harness back in, everything still works and I even have a functioning tach now!
Still a few things to take care of, like the bad IAT sensor and I also have no coolant gauge. Thinking the sending unit is bad? But with it running now I'm one step closer to getting it all back together and back on the road
Psykomantis00
11
Feb 25, 2014 04:52 AM
xerox445
16
Jan 28, 2005 09:10 PM
