b18b in to cx, what motor mounts do i need
Old Nov 15, 2002 | 09:51 AM
JMX's Avatar
JMX
Default b18b in to cx, what motor mounts do i need
ok im gonna be doing a LS swap in to a 94 hatch (cx), i know how to do it all exceopt everbody i ask has a diffrent story on the mounts. i have herd i need del sol vtec mounts, i have herd all u need is a gs-r tranny mount...and on and on
somebody clear this up
now im not sure what tranny i will be using yet (ls or gs-r) but
belive me i have spent many hours searching, but the search sucks on here now, and i need this cleared up
Old Nov 15, 2002 | 10:36 AM
DenMatic's Avatar
Default Re: b18b in to cx, what motor mounts do i need (3232xmj)
theres many configurations to do it.
for my d-to-b swap (in a delsol... same chassis 'eg'), i used:
1. existing manual tranny mount from my d motor (identical to its b counterpart)
2. teg/delsol vtec rear bracket
3. teg/delsol vtec driver's side mount and bracket
4. teg a/c mount for the bottom (cuz i've heard stories about the upper driver's side mount failing)
hydro b-series transmission casings are identical.
if anything is wrong, correct me.
[Modified by DenMatic, 7:40 PM 11/15/2002]
Old Nov 15, 2002 | 01:13 PM
Kataku2K3's Avatar
Default Re: b18b in to cx, what motor mounts do i need (DenMatic)
Just get all the mounts from a 94+ Integra... Del Sol will work too.... The only things that will work off the 99-2000 Si are the front lower mounts.. If your car is a CX you will probably want to get a new rear mount that bolts to the crossmember.. Normally you don't get these with swaps.. And for that too I would just it from an Integra.. They are normally the easiest to come buy... If you really want that motor stiff then just get some Prothane inserts.... For those DC and EG are the same
Old Nov 15, 2002 | 01:40 PM
ls-t del sol's Avatar
Default Re: b18b in to cx, what motor mounts do i need (JDMspecEG6)
"now im not sure what tranny i will be using yet (ls or gs-r) "
if youre going turbo-ls
na-gsr
i assume youre going turbo if you swapped in a ls, so go with the ls tranny
im doing the same swap right now too
LshatchTurbo's Avatar
New User
keep this handy, it should clear up any questions you might have. Good luck
[Modified by lshatchturbo, 5:41 PM 11/15/2002]
Old Nov 15, 2002 | 08:48 PM
JMX's Avatar
JMX
thanks guys this is the best info i have ever found on this subject
93delsolh22
Jul 17, 2011 09:16 AM
92CiviC4dr
Mar 2, 2006 08:04 AM
boosted_dc2
Nov 29, 2004 09:48 PM
275Performance
Jan 10, 2002 07:30 PM
