long term fuel trim / short term fuel trim high
Old Feb 26, 2020 | 09:17 PM
whyS0serious's Avatar
Default long term fuel trim / short term fuel trim high
Hello everyone,
I'm in need of assistance. I just got done finishing my 00 itr build and I keep getting a P0172 / P0170 codes. I went ahead and checked my live data and it showed my long term fuel trim at -16.8% and my short term fuel trim at -20.8%. From what I've been told those specs are out of range which is why it gave me those codes. What should I be checking to fix the long term fuel trim % back to 0 and shorterm to be lower?
Need some suggestions please and thank you!
Old Mar 1, 2020 | 05:00 PM
wunfstgsr's Avatar
Loved
Community Favorite
Default Re: long term fuel trim / short term fuel trim high
Originally Posted by whyS0serious
Hello everyone,
What EMS are you using? stock ECU?
P0172 ACURA Possible Causes
  • Faulty front heated oxygen sensor
  • Ignition misfiring
  • Faulty fuel injectors
  • Exhaust gas leaks
  • Incorrect fuel pressure
  • Faulty Mass Air Flow (MAF) sensor
Make sure your o2 sensors are good ! Check the "Possible Causes" listed above. Visually inspect the related wiring harness and connectors. Check for damaged components and look for broken, bent, pushed out, or corroded connector's pins.
Double check the map sensor O ring!
How's the injectors? try getting them flow tested or try another good OEM set of injectors.
Old Mar 18, 2020 | 05:14 PM
  • Exhaust gas leaks
Hi there,
The culprit was leaky injectors. For those of you having this problem check your injectors. I had mine clean and tested by RC injectors so I ruled them out so I thought they were good but they weren't..
afnan
Apr 3, 2014 02:08 PM
geek504
Jul 5, 2011 11:19 AM
kapoosh valve
Honda Civic (2001 - 2005)
Jul 4, 2010 12:00 PM
mundo
Mar 6, 2003 02:33 PM
