1999 Honda Civic LX passenger wheel vibrating
Old Feb 26, 2020 | 07:04 AM
Eric Roberts's Avatar
Default 1999 Honda Civic LX passenger wheel vibrating
I have and issue with my passenger side wheel vibrating under highway acceleration but it doesn't happen all the time only some time's and it's not affecting my handling or steering. Any advice?
Old Feb 26, 2020 | 07:23 AM
Swift's Avatar
Default Re: 1999 Honda Civic LX passenger wheel vibrating
Swap wheel to the other side and see if vibration follows.
Old Feb 26, 2020 | 07:54 AM
tony_2018's Avatar
Fish Twig
bent rim, unbalanced tire, axle, wheel bearing.
Old Feb 26, 2020 | 07:59 AM
muellersfan's Avatar
The correlation with acceleration would be a good fit for an unbalanced or improperly dampered axle.
Old Feb 26, 2020 | 07:36 PM
Thanks for all the advice. My first thought was my wheel bearing being bad...but I thought that that would be a constant occurrence of vibrations. This seems to be at extreme random and fallows no particular pattern. For instance I did a lot of driving yesterday and it happened a good bit. Today I did about the same amount and it didn't happen at all so I'm unsure if it's my axle but that's my primary suspect right now. I'm open to all the advice that can be thrown at me including issues I might run into in the future
Old Feb 29, 2020 | 09:59 PM
California98Civ's Avatar
Did you try swapping wheels around one at a time to see if the vibration/sound follows a wheel to a new location? It was recommended above by Swift, but you don't mention if you did it and what the results were. You wanna solve this sooner rather than later, your tires/wheels are what keep you from hurtling off the road, suddenly out of control.
Cast_erik
10
Jul 11, 2016 11:14 AM
93Civic_hb
Northeast (Sales)
Oct 17, 2012 06:46 PM
Sic_DA_Nine
Jul 29, 2007 10:27 PM
vandersmissenc
Oct 3, 2005 06:18 AM
