AWD Transmission w/ Quaife LSD, Transfer Case, Shifter Cables, etc.
Prices are with shipping to the lower 48. I'll ship elsewhere for money on top. Local pickup in Detroit. Or I'll drive and meet if it makes sense.
AWD 5-speed transmission from a 2000 CR-V. I had the cases hot tanked, and I painted them before I reassembled the transmission. The
paint isn't holding up that well, as you can see. I cleaned it up some, could use a little more cleaning. No grinds, pop outs, etc. Everything
works perfect. Inside is a Quaife Helical Limited-Slip Differential, modified for AWD. Shifter cables and shifter included in price.
The trans will bolt up to a B series or D series motor (with D2B flywheel and D-series clutch). I welded, drilled, and tapped for a D16. The B
series connections are still available as well. One bolt hole is opened up a little at the top, but it won't make a difference when all of the other
bolts are installed.
Anyways, on to the photos:
Price: $1400 shipped OBO
(I don't want to separate the diff from the trans, but I would for the right price)
Re: AWD Transmission w/ Quaife LSD, Transfer Case, Shifter Cables, etc.
Originally Posted by BoostHatchFreak
Part trade for a gsr trans and 96-00 t bracket and shift linkage?
Sorry, don't really have a use for any of those things. I would consider a trade for some K parts, like: Sidewinder manifold, EKK2 or EKKAWD engine mounts, forged K24 pistons and rods, LSD, Clutch. I think that's about what I need.
