Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Enormous coolant leak on 04 Civic
Old Feb 24, 2020 | 09:41 AM
Sean Jackson's Avatar
Default Enormous coolant leak on 04 Civic
Hi guys, I have this huge leak in the rear part of my engine. Literally as I pour distilled water into my radiator it flows out 2 seconds later in a huge stream over my oil filter as well as dripping down the side of the oil pan. Just as fast as it goes in it goes out. What could it be?
Old Feb 24, 2020 | 09:13 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: Enormous coolant leak on 04 Civic
You have a water pipe that crosses the back of the block under the intake manifold... O-ring sealing it on the water pump end and a pair of coolant hoses along it's length that go to the throttle body/IACV and the heater core inlet. The other end of the water pipe has a short piece of radiator hose sized coolant hose with clamps on both ends and then another short water pipe that terminates at the O-ring sealing it into the thermostat housing. I suggest you get under the car and look up and see where this water is coming from as it is poured in. You may need an additional person to help with this.
Old Feb 25, 2020 | 05:57 AM
NDNV's Avatar
You have this 2004 Civic and a 1996 Civic (from your other posts) both with coolant leaks/issues?
YuJin
Oct 30, 2011 02:21 PM
hAtChBaCkFoReVeR
Nov 12, 2008 12:01 PM
dwuknoit
Mar 16, 2008 07:10 PM
dc2long
Jun 16, 2006 11:26 AM
ATS*Mark
Oct 23, 2005 05:46 PM
