Obd1 motor in an obd2 car
You can start by providing what chassis/ engine is being used.
Convert to OBD1.. OBD1 ECU, ECU jumper harness, OBD1 distributor with jumper harness, OBD1 Alternator. OBD1 engine harness. Not really anything crazy.
Cant I just put my obd2 alternator on my obd1 motor I know I have to use a obd1 distributor but the other parts cant I just swap them off my obd2 motor so I dont have to swap harnesses
If your using your obd2 engine harness then your alternator will work the plugs are different between Obd1 and obd2.
Injectors use obd2 injectors and it’ll plug and play or use obd1 injectors and buy obd2 to
Obd1 injector conversion harness.
distributor is the same way, use obd2 and it’ll plug and play or use a Obd1 distributor and buy conversion harness.
Ecu, use a obd2 from your chassis for gsr or use a Obd1 gsr ecu and buy a conversion harness.
crazy4hp
Feb 3, 2007 09:14 AM
