Honda Accord 2015
Does the vehicle crank but not start or does nothing at all? Have you found a solution to your problem? I would check the lock cylinder and the security system within the car. These vehicles have a chip and it has to be programmed to the security system. If the chip is out of sync it will not start. Normally when this happens there are no signs of the vehicle trying to crank. It normally does nothing and the security indicator on the dash will advise. You can try to put the vehicle in neutral and start it. It could be a fault electrical switch as well.
Amir Alkalay
Jun 8, 2015 09:04 PM
ckr96792
Nov 21, 2011 05:28 AM
prashu123
Jan 20, 2011 11:16 AM
MHonda06
May 16, 2008 07:04 AM
