Suspension & Brakes Theory, alignment, spring rates....
Front Suspension Creaking and Popping!!!
Old Feb 16, 2020 | 03:30 PM
Gman2010's Avatar
Default Front Suspension Creaking and Popping!!!
Removed both front knuckles to replace wheel bearings on 2008 Honda Civic DX/G.
Reassembled with no problems.
Now have squeaking and popping noise from right side?
Any help would be appreciated.
Old Feb 16, 2020 | 04:07 PM
Swift's Avatar
Default Re: Front Suspension Creaking and Popping!!!
Did you reuse balljoints?
Old Feb 16, 2020 | 04:14 PM
Gman2010's Avatar
Yes
Im going to replace the lower ball joints.
Old Feb 20, 2020 | 10:18 AM
416Gang's Avatar
Check the top hats for the struts, also check if you have any loose bolts that connect the strut to the spindle.
Old Feb 20, 2020 | 11:35 AM
Tyson's Avatar
Originally Posted by Gman2010
Removed both front knuckles to replace wheel bearings....Reassembled with no problems.
sounds like you have a problem.... lol.
double check your reassembly. maybe somethings loose, not fully tight, like an axle nut or balljoint nut. im not being an *** or condescending, but there was a change, its the most likely culprit, or at least the first thing to look into than assuming everything went together fine.
check balljoints by jacking the wheel and pulling up. and moving the steering wheel and putting your hand over each balljoint, if you feel any play it needs to be replaced.
what made you think of replacing the wheel bearings in the first place? and 10 years is about right for replacing balljoints anyway, why didnt you replace them in the first place? while the knuckle was already apart...
sanmiguel
Honda CR-V & Element
Jun 24, 2016 09:23 AM
GunSamir
Honda Civic (2001 - 2005)
Oct 27, 2010 07:19 PM
Flash_07
Sep 11, 2005 08:12 PM
civboy115
Dec 23, 2003 09:01 AM
