ZC install questions
Old Feb 16, 2020 | 07:39 AM
HDLLC71's Avatar
Default ZC install questions
Looking for some additional help/info on my swap.
My car is a 91 CRX Si.
donor car is Canadian Del sol 1994 automatic
1.6l ZC (is indeed stamped on the block).
i have the p28 ecu from the car as well.
ordering a full harness/adapter.
question is: donor car is automatic.
i want to use the 5spd from my CRX.
i noticed the flywheels are different part numbers and tooth count.
do I use CRX flywheel and starter? Not sure if that would even work.
or order flywheel for the Del sol engine and use that? Or is that needed?
any other swap parts for that part of the conversion?
exhaust: seems to be a clearance issue (from what I have read in places here). Is that so?
any adaptation needed for the exhaust portion if I use a Del sol header?
thanks in advance!
—JH
Old Feb 18, 2020 | 12:27 PM
~sp33~'s Avatar
EFB055
Default Re: ZC install questions
Does that ZC block have a VTEC head on it?
Use the 5spd flywheel / clutch / pressure plate
Old Feb 18, 2020 | 12:42 PM
HDLLC71's Avatar
Yessir. SOHC VTEC head.
Old Feb 18, 2020 | 12:43 PM
HDLLC71's Avatar
And thank you!
ekay08
Apr 19, 2008 10:01 AM
xxmikexx206
Apr 25, 2006 12:02 PM
bluedelsol
Feb 14, 2003 03:23 PM
