Honda Ruckus and Scooters Ruckus, Silverwing, Reflex, Helix, Metropolitan
Zoomer 6500rpm cut
Old Feb 15, 2020 | 11:33 PM
Leighton Foster's Avatar
Default Zoomer 6500rpm cut
Hi all,
I have an ‘02 zoomer/ruckus that feels like it’s rev cutting at around 6500-6800, if I roll off the throttle I can just get it to creep up to higher rpm.
Bike is standard apart from:
Progress Racing CDI (although tried disconnecting and exactly the same just running off the factory CDI)
Kitaco variator with ~6g weights
Rebuilt carb with 85 main jet
Cheap inductive tachometer
I have tried the basic stuff, new fuel filter and pump, new air filter, new plug and coil.
And with the 85 main it doesn’t look like it’s leaning out after doing a plug chop.
The problem is the same under load or up on the centre stand.
Any advice from anyone who has had a similar issue would be great!
Old Feb 16, 2020 | 04:40 AM
rchid's Avatar
Default Re: Zoomer 6500rpm cut
dumb question but what is the rev limit suppose to be at?
Old Feb 16, 2020 | 08:30 AM
8000rpm with the factory CDI and somewhere around 10,500 with the aftermarket one
Old Feb 18, 2020 | 06:27 AM
rchid's Avatar
have you had a valve adjustment lately? you might not be getting enough valve clearance. You can also do a compression test. I am shooting in the dark at this one so ignore me if you think i'm leading you in the wrong direction.
cb7tuned
Jun 11, 2008 03:43 AM
BoostedSi
Honda Motorcycles
12
Aug 16, 2004 01:47 PM
civicboisi
Jul 22, 2004 04:22 PM
crx00
Jun 1, 2003 11:19 AM
2fcknfst
Honda Motorcycles
Apr 17, 2001 07:57 AM
