Shift Solenoids
Hi, I have a 92 Accord with an auto trans. I am currently installing my own TCM add on computer. I plan to put paddle shifters on the steering wheel.
What I cannot seem to find is a matrix that shows what combination of solenoids make each gear. Does anyone have this information? Thanks for Redaing
Top solenoid is called your lock-up solenoid. It engages at about 35-45 mph in D4. The lower solenoid is your shift solenoid valve. This does the rest of the shifting D1, D2, D3, D4. You can check these valves with an ohmmeter. Test each side of the connector to a body ground a standard: 12-24 ohms.
