Hello my name is Tonya and I have a 2001 Honda Accord Ex..
My 2001 Honda Accord ex is banging the underneath of the front end. I just had the axle changed and the passenger side sway. Bar needed a linkage so..... WHERE DO I go from there? I would apperciate any input to similiar. Equations thanks .................................................. ..............................................A Girl on the Verge of being Stranded!!
I would jack it up by the center lift point then use another jack to raise the suspension to ride hight. Try and force the tire up down left and right. If you have bad ball joints, bearing, or tie rods. Inner or outer you will hear them and notice the movement. Make sure wheel off ground but at ride height. This will give you a clue immediately
also inspect the bushings for strut mount on the control arm
