Turbo choice for stock LS? Critique me
Well looking for a max of 300-350whp. I know the 350whp isn't really this turbos area but I have an idea further into my idea below...
So the setup will be basically a stock B18B1 with the following bolt on parts:
Now to reach the 350whp area maybe not that much but as close as possible. I was thinking of going with some 404 cams and a Skunk2 Pro intake. Oh and I'm strictly talking about 93 octane numbers, no E85 or race gas.
Mainly I'm just curious of the turbo suggestion. I think for a stock non built bottom end LS motor this might be my best option for the cost. If anyone has a better idea for $999 let me know!
- 2.5" intercooler piping
- Garrett 24" wide x 10.5" tall x 3" thick intercooler
- Autoworks Miniram manifold
- Autoworks 3" Vband downpipe with 44mm dump tube rerouted into downpipe
- 3" exhaust to rear
- 44mm Turbosmart wastegate
- S300 Hondata
- Grams 750s
- Walbro fuel pump
350 is do-able. My old LS-t setup made 379, with a cast iron manifold and smaller T3/T4 turbo (Rev Hard kit)….iron-sleeved block, Wiseco pistons, Eagle Rods. Ditch the 404 cams and Skunk2 manifold...
Gt28 is not part of t3 family.... Gt28 is a great turbo just don't think it can quite get there.
If your budget is restricted journal bearings are quite a bit cheaper. I like the Gt28 setup tho just have realistic expectations
I'd like to stick to BB for off throttle response. What got me curious on this setup is I was wondering how much more the .82 housing with true 3" exit paired with the 4" Anti-surge housing will push the regular GT28RS's power potential. It looks like it would be a killer street setup and maybe a middle turbo between the GT28RS and GT2871R.
‘I loved the response of a good t3/t4 back when I had my LS CRX, that thing was fun! I ran around 13psi and it was nasty
still dont know why you dont just throw a vtec head on it....unless your trying to be "different" for the price of cams you can have a better flowing head and a "2 stage" power band that wrecks the LS head even when ported
hmmm my dyno shows gains after 4k when vtec kicks but thats with vtec head never tried a LS. also after 7k power moreless flat lines on my gsr
Would a .82 housing in a GT28RS make it's responsiveness more lazy over the traditional .63? If so I'm curious how much. Example, would a GT28RS with a .82 be about the same responsiveness as a GT2871R with .63?
.82 A/R will make the turbo more laggy in the bottom while adding very little to the top end. I'd recommend going with the 2871 .63 over the 28RS with the .82
One of the smaller trim Garrett T3/T4 hybrids would also be good and within your price range.
I was looking at this, pretty tempting...
GT2871R (compressor wheel trim 48 trim or 56 trim?)
.63 AR T31 Vband discharge
T04B housing for fast spool response
Might be my best option for a stock LS motor and 300-330whp.
I’d read this thread here, https://honda-tech.com/forums/forced...etups-1323059/
you can make a super fun turbo ls without buying a super fancy turbo. It’s a stock Honda motor no need for 1500+ dollar turbo. My brothers stock turbo ls on a old peak boost ram horn kits and it’s awesome. I think he paid 1200 for the full turbo kit used.
Good luck
Good luck
Good luck
Good luck
I'm wanting to put decent parts on this car. Not really interested in a $1,600+ turbo as some people here tend to only suggest
But I do want a entry level BB turbo.
Entry level BB turbo is gonna set you back 1k+ minimum alone..
Depends on which turbo I go with. For whatever reason the GT series are all over the place price wise. Smaller ones are more expensive than larger ones, smaller ones are cheaper than bigger ones, the price seems to be all over the place. Himni racing seems to have the best price though.
