y8 head, y8 adjustable gear, z6 cam, z6 block
Hey guys I'm trying to time my freshly built vitara d16. I'm running z6 block with a y8 head. Inside the head I have a z6 cam the comp59300 with a y8 AEM adjustable cam gear.
Has anyone done a setup similar to this and what did you set your cam gear to for correct timing?
Do you have a cam card for the Comp 59300 cam ? If so, degree it before installing the engine. This will get the cam set correct from the very beginning.
