Turn signal on left side not working. Neither are left side hazard lights
Please help! My left turn signal starts out blinking very fast. After a day or 2 it stop flashing altogether along with my left side hazard lights we can hear the clicking in one of the boxes when we turn them on. Left . side clicks fast with no light inside or out.. If I turn on my hazard light it only blinks on right side! Its time to get my car inspected and I nee help so bad! Please work with me on this.I WOULD BE FOREVER GRATEFUL THIS LITTLE CAR OF MINE IS MY ONLY TRANSPORTATION!!! PLEASE HELP. MY EMAIL IS dianahorto52760@gmail.com.
Fast blinking is usually a bad bulb. It's what indicates one of the bulbs burnt out.
You could also have corroded contacts in the bulb base connector. First thing you should check is the bulbs.
Did you inspect the bulb sockets? I have had corrosion on the contacts prevent the bulbs from lighting up.
You have not provided any of your car information so detailed wiring information is not possible nor advise beyond the simple broken wire or corroded contacts or bad bulbs. Not all cars are built the same and the systems differ to some degree.
You are probably going to be as surprised as I was!!lol. It was the flasher relay! I even cleaned the contacts in bulb socket because like you, I really thought that's where the problem was . But still nothing. So I went ahead and plugged in the new relay and..tah dah... it worked! So happy to have it fixed! I appreciate everyone's responses! I have found out more about my del sol than I hope I ever have to use! Lol. But during all this with the turn signal I found out why my roof leaks (pours) when it rains.. Blew out the drain holes I didnt know I had! It's going to be pouring down here anytime so Im looking forward to seeing what happens! Thank you again and have a nice evening!
baseballbirch
Honda CR-V & Element
Aug 24, 2015 09:08 AM
