Civic EJ9 timing belt tensioner setup
Old Feb 11, 2020 | 12:27 PM
Mihajlo Ilic's Avatar
Default Civic EJ9 timing belt tensioner setup
I have a question about the timing belt tensioner in a Honda Civic EJ9 hatchback from 1997.
Ever since I had the timing belt and other belts and tensioner and water pump changed, theres a noise from 1500 to 2000 RPM. Its probably the timing belt is too tight ?
Honda recommends 44 Nm of torque for the tensioner.
Can I just setup the torque with a key, without opening up the whole timing belt cover ? Just set it to 44 Nm ?
Thank you for answers.
Old Feb 11, 2020 | 02:29 PM
muellersfan's Avatar
Default Re: Civic EJ9 timing belt tensioner setup
It's difficult or impossible to access the tensioner bolt with a torque wrench without removal of the drive belts and upper timing belt cover. That's why I tension the timing belt before installing the cover and drive belts when I replace the timing belt.
This is a rare instance where you should not follow the procedure detailed in the factory service manual.
Ray Hol
Honda Civic (2001 - 2005)
Nov 18, 2014 01:57 PM
SmYrE
Jun 4, 2009 03:42 PM
joe91169
Sep 2, 2007 02:39 AM
melvin
Dec 13, 2005 10:33 PM
