2000 Accord f23a4 manual trans rebuild
Old Feb 10, 2020 | 02:15 PM
JLeff8621's Avatar
Default 2000 Accord f23a4 manual trans rebuild
I am looking everywhere for anything on rebuilding my trans. It is a P2a8 . I cant find anything anywhere . Any advice or info is appreciated in advance!
Old Feb 10, 2020 | 05:43 PM
Aradin's Avatar
Premium Member
Default Re: 2000 Accord f23a4 manual trans rebuild
Most people don't bother rebuilding them as it's generally cheaper and easier to source a replacement unit. That's why you're not finding a lot of info online. If you find the service manual for your vehicle, it will tell you everything down to clearances and torque specs with photos.
Old Feb 11, 2020 | 06:15 PM
JLeff8621's Avatar
Thank you for the response! What other transmissions will pair up to my engine that would be a better option or should I stick with what i have?
Old Feb 11, 2020 | 07:24 PM
Aradin's Avatar
Premium Member
If you're just looking for an OEM replacement then look for one out of a similar year to yours. If you want shorter gears for better acceleration then an H22/H23 transmission. Basically any manual 90-02 Accord transmission or 92-01 Prelude transmission will fit with the exception of the wagon transmissions from the 90-93 models and the SH transmissions from the 97-01 Prelude models. There are also a plethora of JDM variants that will fit. Majority of the JDM transmissions are factory LSD. They are all over eBay.
Old Feb 11, 2020 | 09:55 PM
CannaB00st's Avatar
Are they worth anything though? most of them are like "rebuilt to OEM specs" and 800 is a good chunk of change to drop!
specifically referring to syncrotech ones or https://ebay.to/2UQAT73
Old Feb 13, 2020 | 08:26 AM
JLeff8621's Avatar
So any of those transmissions will bolt directly to my f23?
Old Feb 13, 2020 | 12:50 PM
Aradin's Avatar
Premium Member
Yes.
hynx
Dec 16, 2014 09:37 AM
52172
Apr 10, 2007 09:05 PM
djswitch
Mar 26, 2004 07:42 AM
