Mb6 vtis no spark, need ideas
Old Feb 10, 2020 | 10:07 AM
Hughes07's Avatar
Default Mb6 vtis no spark, need ideas
I’ve got an mb6 vtis b18c4, the car was a rolling shell, it’s had a b18c4 dropped in from a donor aerodeck, everything was running fine but once in it’s got no spark.
Changed the dizzy for a definite working one so it’s not that, tried a different ecu, it’s got 3 earths so unlikely to be that and changed the main relay.
The dizzy is definitely getting power as well.
has anyone got any other ideas? When I got the shell a few wires were disconnected from the drivers side fuse box, could it be anything in that area that would cause it?
Old Feb 10, 2020 | 10:24 AM
muellersfan's Avatar
Default Re: Mb6 vtis no spark, need ideas
Does the fuel pump prime?
What CEL codes are stored in the ECU?
What year mb6?
Old Feb 10, 2020 | 10:35 AM
Hughes07's Avatar
Yeah the pump primes, no codes on the ecu.
its a 1999 plate
Old Feb 10, 2020 | 10:41 AM
its a 1999 plate
For 99-00 Civics, the distributor coil and ICM circuits are protected by dash fuse 9. Start there.
Old Feb 10, 2020 | 10:43 AM
Hughes07's Avatar
Thanks, appreciate it bud, I’ll try tomorrow
Old Feb 10, 2020 | 10:46 AM
If fuse 9 is fine, next check whether battery voltage reaches the coil and ICM in the distributor.
You should also check whether the timing belt snapped or stripped.
stevejames
Nov 24, 2016 01:23 PM
jackhatch
Sep 26, 2011 07:33 AM
blaze_32001
12
Jul 7, 2007 08:45 PM
slvrcvc93
Apr 28, 2007 06:52 PM
SiHatchTurbo
Sep 6, 2005 12:48 AM
