Need help f22a1
Best you can do is buy a throttle body spacer and taper bore everything to match your new throttle body. The stock opening on the intake manifold can only be bored out to ~63mm before busting through the aluminum. So 70 down to 63. Even after doing all that you're probably going to notice it's lazy when you jump on the throttle because you slowed the air velocity down so much.
Thanks, is there anything you can do to these motors to get more power. I put on a msd cap coil and rotor, aem fuel rail and regulator, Bosch 315cc injectors and maybe a little more
I agree with Aradin... swap that big single-jingle out for a H22A or JDM H23A and let 'er rip tater chip. Otherwise, you will be spending big cash on a turbo kit.
Gordo_eg
Nov 8, 2016 04:32 PM
slide inside
Oct 21, 2009 01:15 AM
949
Dec 3, 2008 03:06 PM
