94 Honda Accord
Old Feb 8, 2020 | 11:30 AM
FRESHBERRY11's Avatar
Default 94 Honda Accord
Hey I’m new to this. I bought a 94 Honda Accord. For the past week all the gears were engaging and working fine. Then a few days ago they weren’t. They said it could’ve been the clutch master cylinder so I changed it. Nothing. Then they said it could’ve been the slave cylinder so I changed it. Nothing again. Could it be the clutch itself? Also the gears engage when the car is off but when I turn it on they don’t engage. Any help?!?!
Old Feb 9, 2020 | 04:14 AM
99stockcivic's Avatar
Default Re: 94 Honda Accord
If a car won't go into gear I would suspect throwout bearing. Or it could mean the pressure plate fingers are broken. Unfortunately if this is the case, this means the clutch needs to be removed to inspect and replace the broken part(s). While there, I would replace the clutch and flywheel, since it all has to come out.
Old Feb 9, 2020 | 06:21 AM
Cool I’ll try that today. Thanks!!!
Sir001
Apr 15, 2017 07:32 PM
Sopheap Sao
Lighting
Mar 11, 2016 03:43 PM
mattp27
Mar 4, 2013 07:50 AM
nigelalan
May 8, 2010 07:13 AM
lango-H22
Oct 26, 2009 09:06 PM
