2000 Civic Ex rpm
Old Feb 6, 2020 | 09:40 PM
VtakZach's Avatar
Default 2000 Civic Ex rpm
Bringing this topic from the dead.
2000 Civic Ex with a 1994 gsr & obd1 p72.
stock ex harness with ecu & distributor jumper harness.
problem: no rpm signal. Already tried splicing from the dizzy signal wire to the back of the tach.
Old Feb 7, 2020 | 06:06 AM
muellersfan's Avatar
Default Re: 2000 Civic Ex rpm
Test continuity of blue rpm wire from ICM to cluster.
Check for rpm from ICM and blue wire using frequency (Hz) setting on multimeter.
Test tach in cluster.
Old Feb 7, 2020 | 06:07 AM
VtakZach's Avatar
Check for rpm from ICM and blue wire use frequency (Hz) setting on multimeter.
Ill try that, however I’ve used 2 different clusters and a different dizzy. Would the crank position sensor have a play in this?
Old Feb 7, 2020 | 06:08 AM
A multimeter will solve the mystery.
No
Old Feb 7, 2020 | 01:01 PM
wunfstgsr's Avatar
Loved
Community Favorite
Its probably the jumper harness, is it a OBD2B distributor jumper harness?, The 2000 civic is OBD2B it gets the RPM signal from the ECU.
Rukusmasta2
Northeast (Sales)
Dec 3, 2011 02:40 PM
slo_ej8
Apr 9, 2008 09:01 PM
Jim Truett
Apr 1, 2008 08:11 AM
daanswer12000
May 23, 2007 03:53 PM
