D15z4 throttle body/stock air filter
Good day honda tech
Just a nuob question, any ideas how I can remove my stock manifold and air filter?
I need to replace these small tubes and the fuel rail throttle body is hindering me to remove it.
Hope someone can help Thanks
[img]blob:https://honda-tech.com/fdcea52d-cfde-4675-8f3a-8f692f86f7ab[/img][img]blob:https://honda-tech.com/faa56db7-039c-455c-a60d-722110b00d28[/img]
Unfortunately I cannot see what you circled being the photo is a bit small for the business in the area you circled.
A slightly larger image or a closer view may prove helpful.
Also, if I may inquire, what domestic market is the D15Z4 motor from? I do not believe it is from the USDM or CDM markets. This information may prove helpful.
thanks for the reply
I will send a clearer image as well as my civic is gulf specs so im pretty sure its not jdm or usdm
