Difference between mini ram and ramhorn turbo height placement?
For a daily driver I'm concerned with how low a mini ram manifold might mount the turbo. Concerned with objects hitting it and also if I were to run through standing water while driving. How much higher does a ramhorn place the turbo?
Re: Difference between mini ram and ramhorn turbo height placement?
Your overthinking this, get a air intake for the turbo and your fine even without one it wouldn't suck up water it's not that low basically more less sits at the top of your block. To answer your question a few inches
I'm not worried about that part. I plan to run a custom intake/filter up to the fender area where the washer fluid reservoir is.
Running a miniram myself, I have no fear of dunking the turbo at all. It stays in a comfortable position.
Thanks for the pics, yea that looks fine. Somehow in my mind I envisioned it sitting much lower than that due to the turbo draining issues people tend to run into.
I've read the minirams have problems with boost creep. Is this accurate? I was thinking of going with a 44 over a 38 due to this.
I have pushed 12 psi on an 8lb spring and have had ZERO creep on this setup with a 38mm tial. Currently pushing 25.. You WILL have mild difficulty routing your return but, it CAN be accomplished!
I have pictures of Lightningteg's drain setup and it looks easy enough.
I do plan to re-route the dump tube into the downpipe. I wonder if that increases the risk of boost creep or not. I haven't bought the wastegate yet so 38 or 44, doesn't matter to me. I need to get Autoworks on the phone, tried today to no luck.
Running the same manifold and wastegate setup as Txdragon. Spring holds 8psi and I have it boosting up to 17.5 on the street and holds great. Greg does beautiful work
totally depends on the turbo
Virtually no Honda manifolds made to date prioritize the wastegate so if you put a big old honking turbo on one your gonna have problems regardless.
For what you want I don't think it'll be a problem.
Boost "creep" wouldn't be an issue, but boost response using a boost controller can be affected depending upon how well you route the dumptube into the downpipe stream. :Hint: the smoother the angle into the rest of the downpipe stream, the better results you'll get.
On the recirculated WG topic, there is lots on the WWW to look through but what I hadn't really come across is a dyno comparison between dumped vs recirculated wg. Seems the only benefit to doing this is simply noise reduction since there is no power gained (or nothing solidly proven), and higher chance of diminishing power if it isn't routed properly.
Thanks guys, got an Autoworks miniram on the way now with 3" downpipe and 44mm wastegate re-routed into the downpipe. I told Greg about the concern with the angle of the dump going into the downpipe and he said not to worry that he's got it and does this a lot. Fair enough!
Lightning and Shodan you can say I've dragged my feet but this time around I'm actually spending money! Garrett intercooler and manifold/downpipe off the list.
Originally Posted by Nathan937
I like those manifolds. I would imagine the drain is pretty close to level to the top of the pan no?
That's the recommend location for it even though I've seen a few people put it on the lower portion. Those who do that likely have no clue what they're doing. haha
Picture trickery! Or, my eyes are getting old.. Looked like a sensor in the dump tube. Lol!
Lightning and Shodan you can say I've dragged my feet but this time I'm around I'm actually spending money! Garrett intercooler and manifold/downpipe off the list.
