Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
O2 Sensor Question - Part#
Old Feb 3, 2020 | 08:42 AM
blueknigh7's Avatar
Default O2 Sensor Question - Part#
I'm trying to fix up a 2005 Civic DX that's new to me, 90k miles. Initially it wouldn't pass SMOG due to a P0139 problem (O2 sensor slow response, Bank 1-Sensor 2). There's only BOSCH sensors around here, so I use it for the immediate fix on the downstream O2. Clear the code and it drives fine. After about 40 miles, it's now throwing P0420. I wanted to get some 2nd opinions as that's what the Internet is good for. I know it could be the cat, the upstream O2 sensor, or maybe I got a bad/wrong downstream sensor (for the wrong engine ID - I didn't know they were that specific until today)?
  • After researching, I don't think its the cat as it drives fine (to me anyway), plus the SMOG test had all acceptable values in the actual measurements.
  • I'm up for replacing the upstream O2 sensor, but there's several part numbers on rockauto for denso.
Anyway, just wanted to get some thoughts before I throw more (expensive) parts at the problem. Are civic's picky about their O2 Sensor for each submodel? I'm thinking about getting an O2 sensor for the correct engine first... *sigh*
EDIT: I just did a VIN lookup, and it says it's a Civic EX (2dr coup, AT), which matches the BOSCH sensor I bought. So I'm pretty sure the O2 sensor is right at this point, just a Bosch.
Cheers!
Old Feb 3, 2020 | 10:16 AM
NDNV's Avatar
Default Re: O2 Sensor Question - Part#
Don't use BOSCH. Use OEM Denso or NTK.
EG92DX
Southern California
Jul 7, 2012 07:54 PM
phoshyzzle
Oct 18, 2009 07:52 PM
utn
Aug 25, 2009 06:48 PM
Integra_Boi
Oct 1, 2004 08:07 AM
SpiceyRice
Jul 5, 2004 08:33 AM
