Product inquiry feedback:Borg Warner SXE257 line
Old Feb 2, 2020 | 11:49 AM
CARLOS LOPEZ's Avatar
Default Product inquiry feedback:Borg Warner SXE257 line
Anyone have any experience with borg warner turbos? I was thinking about the bw s257 sxe. I have a hp goal of about 500hp to the wheels. B18c with a css 82mm 10.1 cp pistons, speed factory rods, stock port gsr head with supertech valve train. Stock cams. Any advice would be appreciated thanks
Old Feb 2, 2020 | 02:52 PM
BoostHatchFreak's Avatar
Default re: Product inquiry feedback:Borg Warner SXE257 line
Don’t think a lot of Honda people have used it but it is a highly used turbo among the subie community.
Old Feb 2, 2020 | 03:32 PM
2kdrift's Avatar
I have a BW made 400 on a much smaller turbo on a very similar setup,impressive spool. s256 / S257 Looks a about right for your goals. IMO just as good as garrett or others its all about finding something that matches your build
BEP Batmowheel S252 / based on S252 SXE
Ram horn Manifold
different tuner
Old Feb 3, 2020 | 12:30 AM
Balor_Gr's Avatar
Airwerks Turbos are great but they need that costly divided setup. If you dont use it they some how seem to be lazy on open turbine housings unless you run the .55 a/r.
If you want a reliable JB T3 open turbo on the budget side go for either a T3 stage 3 turbine wheel garrett or T350 stage 5 turbine wheel based turbo. Or even a TNX turbonetics.
Old Feb 3, 2020 | 09:23 AM
TheShodan's Avatar
Moderator
Lots of BW users here, but may not be that specific model. But you need to know what you're looking at.quality is on similar range as Garrett performance. All depends upon budget and purpose.
Xperience
Jul 29, 2014 08:52 AM
OMG THE GOGGLES
13
Feb 26, 2009 01:56 AM
B6tizzleHatch
Jan 5, 2007 12:27 PM
eg6madness
Sep 23, 2006 03:30 PM
DaveF
Jun 17, 2003 12:43 PM
