Radio/headunit stopped working
Old Feb 1, 2020 | 06:42 AM
White_EG1's Avatar
Default Radio/headunit stopped working
Ok so I have Sony headunit, upon starting up my car and driving away the radio just shut off and has not came back on. I had this happen before on another car and I know this should be a easy fix but I’m just trying to remember how I did it.
I should start with the radio fuse under the dash correct? What number is it? And I believe last time I replaced it I used a back up fuse to replace it but I don’t remember where I pulled it from
Old Feb 1, 2020 | 09:22 AM
hatchaholic's Avatar
10 Year Member
Loved
Community Favorite
Default Re: Radio/headunit stopped working
In a 96 hatch stereo is fuse 28. With aftermarket hope the installer used the same circuit. Also check the ground wire. Good luck! I have little faith in aftermarket installs cuz of shoddy wiring people do.
Old Feb 1, 2020 | 10:43 AM
muellersfan's Avatar
15A Fuse 23 for EG.
Old Feb 1, 2020 | 11:52 AM
White_EG1's Avatar
The thing is it was working fine for a year, and it just stopped. Clock works fine
Old Feb 1, 2020 | 01:00 PM
You should now conclude that the dash radio fuse is fine.
Old Feb 2, 2020 | 11:28 AM
10 Year Member
Loved
Community Favorite
Crappy connection somewhere that finally came loose...wires routed across something that cut them...ground point that corroded... Pull the radio out and try to trace wires. Usually yellow is power, blue with a white stripe is remote on, black is ground.
Old Feb 4, 2020 | 08:43 AM
White_EG1's Avatar
The 15A that was in there was blown. Threw a spare 15A in and it blew as soon as I turned the key. Put a 20A and it turned on and works good, what’s the deal?
Old Feb 4, 2020 | 09:07 AM
Fire risk
Old Feb 4, 2020 | 10:21 AM
White_EG1's Avatar
What? I don’t understand lol
Old Feb 4, 2020 | 10:56 AM
Fuses have specific amperage ratings for an important reason - to protect the circuit and to prevent fires. Simply put, installing a fuse with an amperage rating higher than indicated by the manufacturer is dangerous.
Old Feb 4, 2020 | 11:49 AM
White_EG1's Avatar
So why did the new 15A fuse blow when I put it in
Old Feb 4, 2020 | 11:52 AM
Are you familiar with the term "short to ground"?
Old Feb 4, 2020 | 12:35 PM
White_EG1's Avatar
No I’ve never touched wiring before honestly. The stereo was installed by previous owner
Old Feb 4, 2020 | 01:50 PM
^Not particularly relevant information with regard to diagnosis
Old Feb 4, 2020 | 03:58 PM
White_EG1's Avatar
So am I ok with the 20a fuse atleast
Old Feb 4, 2020 | 04:12 PM
Old Feb 4, 2020 | 11:03 PM
White_EG1's Avatar
Well i don’t know where to go from here, you could tell me where the ground wire is that’s shorting? Is it the wire going to the head unit? And what do I do when I find it
Learn me
Old Feb 4, 2020 | 11:41 PM
White_EG1's Avatar
When I turn on the car the radio dies
Old Feb 5, 2020 | 06:21 AM
Behind the radio, carefully inspect the radio power wire protected by the radio dash fuse. Look for damage or sloppy past repairs. Repair damage or run a new wire.
Old Apr 17, 2020 | 08:55 PM
White_EG1's Avatar
Finally looked at it and the illumination/dash light wire is not in the butt connectors, the wire is cut at the top a bit.
Is this my problem? How do I repair the wire? Just throw another connector on it?
Old Apr 18, 2020 | 09:18 AM
White_EG1's Avatar
Bump
Old Jun 1, 2020 | 07:19 AM
White_EG1's Avatar
Well whenever I make a thread and my problem gets fixed I like to update the thread with how it happened.
It was the headunit I threw in my old one and all is well again.
I blame the illumination wire? And the deck was from 2009
Old Jun 1, 2020 | 07:20 PM
b_boy190's Avatar
The illumination wire is not needed on alot of the newer vehicle because the harness for the radio is connected to the dash harness, which in turn is linked to the dash illumination switch by the drivers side air vent. I have 2 alpine radio's that don't have the illumination attached. These are old school radios too (ALPINE CDA-9887)
Check the back of the radio for a small fuse and see if thats blown or even present. With radios its actually pretty easy cause it is a simple setup. Just remember that its an old vehicle and these harnesses are starting to show their wear and tear.
Old Jun 1, 2020 | 08:20 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
And as for fixing a broken wire, you either run fresh wire from point A to point B or you crimp and tape up the break in the original wire making sure it can't touch and short anywhere else or to another wire.
Old Jun 2, 2020 | 09:19 AM
White_EG1's Avatar
Yeah actually the illumination wire looked like it got cut in half and the wire side was exposed with no tape or anything which I think that could’ve been the culprit. But the deck was always weird it was programmed backwards so the buttons never went to the actual function
I ended up using the old radio harness which was mint. And all is good, I’m just glad to have some tunes again, so now it’s time to fit one of those nice apple car play double din in the sol!
