O2 Sensor Compatibility?
It looks like the plug and terminal configuration is identical between EG Civic/OBD1 Integra/OBD2 Integra.
The sensor my little Si Hatch calls for has the longest leads (just under 17") and looks to be less 'spensive than the Integra ones.
Denso # 234-4099: https://www.densoproducts.com/product.aspx?zpid=18065
Looks like it was used from '92 to '00.
Any problems using this for my B18C1 equipped EG hatch?
Thanks for weighing in.
This is the o2 sensor listed for my stock Si hatch w/ the D16, so I don't think an extra 0.2L (12 cubic inches) from the B18 will overwhelm the sensor. It also crosses w/ the '96 del Sol VTEC which is my "go to" bridge for EG to B18 pieces.
Since it has the longest lead, I am hoping we won't have to splice in an extension like we did when I put the header on.
Of course after I ordered the Denso 234-4099 w/ 16.5" lead, I figured out there is another Honda o2 sensor that fits our EG chassis that has a 20" lead:
https://www.densoproducts.com/product.aspx?zpid=18031
If it's a 4 wire o2 sensor, it will work on anything requiring a 4 wire o2 sensor as long as you have the right connector and the terminals in the right locations.
I said F it and spliced in an extension to get me from the header to the connector. Hope to install this weekend!
Be sure to use shrink wrap and solder them to be extra safe! also use some wire loom to protect the extended wires from heat.
I also kept the original wire harness sleeve from some previous O2 sensors to use on this - that stuff is nice!
GSR-EG-92
Mar 11, 2009 06:32 PM
recognize408
Jun 28, 2006 09:49 PM
