Replaced CG3 Gas tank, fuel lines, brake lines
Old Jan 29, 2020 | 05:18 AM
typhoon's Avatar
Default Replaced CG3 Gas tank, fuel lines, brake lines
Here is a link to my blog post about replacing my Gas tank, fuel pump, filler neck, rear struts, fuel lines, and rear brake lines on my CG3
It's not a detailed step-by-step, but rather an overview of all work, if you are considering doing this project yourself.
https://motoluvr.blogspot.com/2020/0...-update-1.html
Old Feb 3, 2020 | 06:15 AM
r_kage's Avatar
Default Re: Replaced CG3 Gas tank, fuel lines, brake lines
I wouldn't mind knowing the steps you took before starting your car. I'm about to that point.
Old Feb 3, 2020 | 04:00 PM
typhoon's Avatar
Not sure what you mean. I primed the pump several times (key on, engine off) to make sure of no fuel leaks before I started it. That showed me I had to tighten my return line at the pressure regulator.
Old Feb 8, 2020 | 08:45 AM
Stelcom66's Avatar
That looks great.That had to be quite a job. Last fall I had the brake and fuel lines replaced on my '99 Accord by a shop. They make the brake and fuel lines there, supposedly with better material than original. I recently also had part of a brake line replaced on my truck. The snow removal chemicals in my state do a number big time on brake and fuel lines. I heard that ironically in Maine, where winter weather is more severe - less damage to the lines is typical because they don't treat the roads with chemicals that are very corrosive to metal.
Scumlord47
Apr 1, 2019 01:05 PM
tyoung8386
Nov 6, 2017 01:47 PM
blackeg
14
Mar 16, 2016 09:43 AM
TAP
Suspension & Brakes
Jul 13, 2010 05:32 AM
jason0123
Aug 12, 2009 05:03 PM
