1998 Honda Accord transmission.
Old Jan 28, 2020 | 08:30 PM
Hondafixa's Avatar
Default 1998 Honda Accord transmission.
Hello I have a 1998 Honda Accord 4cyl and it's throwing 3 codes p0706, p1705, p0700. I've replaced the transmission range sensor couple times now and it kinda worked but now it will fail every time. It will slam and jerk into gear and flash D4 and if I shut it off I have to pull battery terminal and back up ECU fuse. The wiring harness is just fine and I got a couple range sensors from junk yard but I can't figure this out. Do I need a new pcm, transmission or a wiring harness?
sycomajor
Jan 12, 2015 12:42 AM
k24a8
K Series
Sep 11, 2013 04:35 PM
Kss
Sep 19, 2012 04:02 PM
1990crx
Jun 23, 2006 11:39 AM
CIVICHB1
Mar 21, 2005 09:20 AM
