d15b7 connecting rod/piston rings
Ive done the search and cant seem to find the answer. ITs a 1995 Civic lx d15b7 engine. Is there a way to replace the piston rings WITHOUT removing the main bearing saddle/cradle? I don't want to disturb anymore than I have to on this engine. I don't think it can be done but figured I would ask anyway
Thanks
Thanks
Thanks
Thanks
Also pistons are supposed to come out the top of the block so the head will have to be remove too.
Really, if you are re-ringing the car it's best to pull the motor out, get it on a stand, clean her up a **** ton and then work in a clean environment for assembly. Also, typically if re-ringing the car, you take the motor fully apart, order new pistons and rings, send all the necessary parts to the machine shop for hot tank cleaning, bore and hone at the bare minimum.
b18c5_ej8
Nov 26, 2011 05:07 PM
OldSchoolSwap
Apr 22, 2011 03:59 AM
