Front Lower Brace
Old Jan 25, 2020 | 09:41 AM
Sielu1995's Avatar
Icon5 Front Lower Brace
I'm looking at option for front lower 4 point braces and thus far am only finding units from Megan Racing and NRG Innovations. The problem is the Megan unit is not usable as it doesn't clear the cat while the somewhat less rigid NRG unit does. Is anyone aware of a safe, viable way to use the Megan brace and still retain the cat?
Old Jan 26, 2020 | 03:53 PM
Freedo_Civegra's Avatar
Default Re: Front Lower Brace
Go to an exhaust shop and have them move the cat farther down. If your o2 sensor wire won't reach, ebay has a ton of honda 4-wire o2 sensor extensions for sale.
Also, whichever brace you get, make sure to get some longer control arm mounting bolts. Toyota has some 82.5mm bolts that work perfectly. The part number is SU003-05213.
Old Jan 26, 2020 | 04:01 PM
tony_2018's Avatar
Fish Twig
Good to know.
Old Jan 27, 2020 | 02:04 PM
Relic1's Avatar
I've had both, found that with them I had clearance issues with some speed bumps and track side curbs/rumble strips.
I run the factory Integra front lower tie bar that sits on top of the subframe with zero issues.
Old Jan 27, 2020 | 02:50 PM
Sielu1995's Avatar
Thank you Freedo and relic1 for the info. Saving it on my comp now.
With the front tie bar, on the 99 civic ex i had at the time, with 1.50 inch drop i never had contact issues.
Old Jan 28, 2020 | 07:48 AM
BiggieBert's Avatar
Loved
Community Favorite
Ultra Racing makes a front lower bar as well.
Old Jan 28, 2020 | 08:01 AM
Sielu1995's Avatar
I just checked Ultra Racing and am only finding a 2 point brace for the lower front
DaveF
May 15, 2008 02:57 AM
xjohnx
Sep 26, 2006 06:29 PM
dohc-nyne
Apr 22, 2003 09:04 AM
es four
May 22, 2002 06:55 PM
