91 Civic Si, 1.6L head gasket/head bolts/valve stem seals
Old Jan 25, 2020 | 05:58 AM
civicali's Avatar
Default 91 Civic Si, 1.6L head gasket/head bolts/valve stem seals
Want to purchase the head gasket, head bolts and valve stem seals for my 1991 Honda Civic Si, 1.6L, Hatchback, (D16A6).
I have the following part#s so far and want to make sure they are the correct parts before I purchase them:
Gasket, Cylinder Head (Ishino Gasket) - Honda (12251-PM5-S02)
Bolt A, Cylinder Head Cover - Honda (90014-PM3-000)
Seal A, Valve Stem (Nok) - Honda (12210-PZ1-004)
Seal B, Valve Stem (Nok) - Honda (12211-PZ1-004)
Question on the valve stem seals.
I see that there are two different part numbers for the valve stem seals, Seal A and Seal B. How many do I need to buy of each?
Never done this job before so its a learning experience for me.
Any advice is greatly appreciated
Old Jan 25, 2020 | 06:26 AM
Marcos Barrios's Avatar
Default Re: 91 Civic Si, 1.6L head gasket/head bolts/valve stem seals
for your valve stem seals you need 8 of each
8 for intake side and 8 for exhaust side
Old Jan 25, 2020 | 10:02 AM
civicali's Avatar
Got it,
Thanks
Old Jan 25, 2020 | 10:05 AM
jlicrx's Avatar
if you want head bolts, they are 90005-PM3-004 bolt/washer (10 required) - the 90014-PM3-000 bolts are for the valve cover (2 required) - they bolt down the camshaft cap near the distributor and have threaded stud on top for the valve cover
the numbers you have for valve stem seals are correct - seal A is for the intake valves and seal B is for the exhaust valves
head gasket part no. is correct
Old Jan 25, 2020 | 10:08 AM
civicali's Avatar
Friend has a 1994 Honda Civic Lx (1.5L) and also has a blown head gasket but he's going to try to fix his issue using "Bar's Leak HG-1 HEAD SEAL Blown Head Gasket Repair".
What are the Pros and Cons?
Last edited by civicali; Jan 25, 2020 at 11:43 AM. Reason: Correction to year of vehicle
Old Jan 25, 2020 | 10:13 AM
jlicrx's Avatar
replacing valve stem seals
Old Jan 25, 2020 | 10:14 AM
jlicrx's Avatar
Originally Posted by civicali
Friend has a 1996 Honda Civic Lx (1.5L) and also has a blown head gasket but he's going to try to fix his issue using "Bar's Leak HG-1 HEAD SEAL Blown Head Gasket Repair".
waste of money - not going to work is the main con - don't know of any pros
Old Jan 25, 2020 | 10:28 AM
civicali's Avatar
Good info
Thanks
Old Jan 25, 2020 | 05:31 PM
civicali's Avatar
I found a remanufactured head for sale by J and C Enterprises (e bay). Cost is $249, One year warranty.
What are things to watch out for when going this route and buying a head off of e bay.
HONDA CIVIC CRX 1.5 1.6 16V SOHC NON-VTEC CYLINDER HEAD CASTING PM3 PM9 88-95 | eBay
Anyone know of a good shop in the Los Angeles area where I can take the head in for a rebuild?
Old Mar 7, 2020 | 06:22 AM
civicali's Avatar
Purchased a used head for 150$.
Going to start removing bolts and other parts so that I can get access to the cylinder head
Question?
Do I turn the crank shaft clockwise or counter clockwise to reach Top Dead Center (TDC) at the number 1 cylinder?
averyvm
Jun 13, 2007 01:41 PM
98GSRDC2
Mar 5, 2007 10:13 AM
Hondica
May 2, 2004 11:53 AM
jeremy.
Feb 3, 2004 10:14 AM
Austin
Jan 31, 2002 10:17 AM
