97 fb221 vtec manual problems
Old Jan 24, 2020 | 01:22 PM
Colinshondturd's Avatar
Default 97 fb221 vtec manual problems
Hey new to this form and new to Honda’s....please move if not posted in correct thread....
Major problems
-Scanned it and got p0141 code (o2 sensor)
-On start up it idles at 1500 and than starts jumping between 1500 and 2000
-Give it gas and the motor loses its ****, starts running like it’s air fuel is fucked up and dies
-While driving it I hit the gas and it’s like it’s not even there
-Also for some reason just doesn’t enjoy being in 3rd for long and it’s a pain in the *** to get in reverse
Now I’m thinking it’s either the air idle sensor, tdc or tps but I get no codes for those only the o2
Any ideas would be appreciated thank you
Old Jan 25, 2020 | 02:55 AM
angrysmileyface's Avatar
Default Re: 97 fb221 vtec manual problems
Try cleaning the iac valves screen, the throttle body, and check tension on the throttle cable. Also check fitv and vacuum lines for leaks
Old Jan 25, 2020 | 03:00 AM
I’ll try cleaning the throttle body today and I’ll check the cable
Im pretty sure I don’t have a fitv I’m a 97 vehicles before 96 normally have them
Also would the ac lines not being connected have anything to do with the engine itself
edit: just noticed while I was driving I lost my rpms battery also isn’t staying charged
Old Jan 25, 2020 | 06:11 AM
You have a fitv unless some one removed it with a block off plate. As for lost rpm, it's possible you have a wiring problem, a faulty distributor or failing crank sensor.
Old Jan 25, 2020 | 08:00 AM
Where’s this line go to
Old Jan 29, 2020 | 01:26 PM
I figured everything out I narrowed my problems down to the eld
Old Jan 30, 2020 | 01:20 AM
Steve Massey's Avatar
Major problems
check the pcv valve and it's hose routed to the intake manifold. Also check your coolant level. The idle up and down was happening on both of my 94 accords because of a stuck open pcv.
mrmiatagi
May 3, 2011 07:06 AM
bigizsosexy
Jun 16, 2008 02:29 PM
CDMNG
Jun 4, 2006 08:03 PM
scooterguy
Nov 26, 2005 08:10 AM
