99 accord V6 hard to start at lower ambient air temps.
Old Jan 21, 2020 | 09:02 PM
Discoscotch's Avatar
Default 99 accord V6 hard to start at lower ambient air temps.
I have a 99 Accord V6 and it doesn't want to start when the temp drops below about 50°f. Fuel pump seems fine. Pumping gas pedal does not help, in fact I've found the best results by not touching the pedal at all and not cranking for a long time, rather given it a two-count and stop. Wait a few seconds and crank for a two-count and stop. When it does start it runs rough until warmed up, then it's fine. As long as I don't let it fly cool off it starts normally. If it does cool off problem returns. Not sure if there's already a thread going on this, but I didn't see one at first glance. Apologies if there is. I'm between jobs so need to get it going ASAP so I can keep up the job hunt. Thanks in advance!
Old Jan 22, 2020 | 10:50 AM
99stockcivic's Avatar
Default Re: 99 accord V6 hard to start at lower ambient air temps.
First guess is to check / clean Idle Air Control Valve. I can see temps giving bad info and so it won't work when cold.
Hopefully this helps show you where it is and how to clean it.
dmdit2
Oct 18, 2014 09:40 AM
jsmoothy78
Jul 12, 2008 04:22 PM
woolleyfooley
Dec 10, 2007 01:07 PM
EKBOOSTDREAMS
Jan 20, 2007 12:06 AM
