Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
2018 Pilot EXL transmission fluid change
Old Jan 21, 2020 | 04:14 AM
Andrew75's Avatar
Default 2018 Pilot EXL transmission fluid change
I am.getting ready to change the fluid but have few questions. I have seen where you are suppose to add 3.5 to 3.2 qts. Could someone confirm the amount added and the amount of torque on the bolt. I think I know which bolt it is but if anyone has a picture that would be helpful as well. I did this to my 16 Accord but have been unable to find any resources for the Pilot.
Thank you,
Old Jan 21, 2020 | 09:59 AM
canister's Avatar
5 Year Member
Default Re: 2018 Pilot EXL transmission fluid change
Torque the drain bolt by hand with a regular short wrench or ratchet. Once you feel it is not moving, stop. Do not apply excessive force. It is really that simple.
The fill bolt is a different story. They use 800 lb gorillas in the factory to tighten them and you may end up needing a 3/4" drive breaker bar and the matching 17mm socket.
Old Jan 21, 2020 | 10:21 AM
Andrew75's Avatar
Thanks for the input. I didnt think they had a fill bolt or a check bolt. My 2016 accord had one. I assume we are talking about the same thing where you can check the level of the fluid to make sure there is not too much in there.
Thanks
Old Jan 21, 2020 | 10:34 AM
canister's Avatar
5 Year Member
You can use the dipstick tube to fill too, it just takes too long for my liking.
imadigitalgod
187
Apr 23, 2016 07:08 AM
elonfirefighter
Mar 1, 2014 08:05 PM
bad 91 teg
Feb 1, 2011 04:09 PM
nixadm
14
May 7, 2006 09:28 PM
ocdcivic
Dec 11, 2004 10:11 AM
