HELP// Bleeding Master/Slave Cylinder
Old Jan 20, 2020 | 01:14 AM
SCMFOX's Avatar
Default HELP// Bleeding Master/Slave Cylinder
I have a 1997 Accord Ascot and ive just replaced the master and slave cylinders and tried to bleed the fluid myself however i cant even get any fluid out at all and the reservoir doesn't bubble. please help. TIA
Old Jan 20, 2020 | 06:54 PM
Efmysedan's Avatar
Default Re: HELP// Bleeding Master/Slave Cylinder
Some diy action huh this is what happens
when the forums drop a link to a video or writeup and tell you it’s easy lol
not your fault
buy rubber tubeing/hose that is sized to fit snugly on the bleeder valve of both the slave cylinder and the front left brake caliper. Check to see if they are different sizes. Get enough to attach one end to the bleeder on the slave and the other end to sit inside the the slave cylinders resivior. Not deep in the resivior to where the air bubbles circlulate back into the system. Your just recycling the fluid and the bubble with escape there. crack the bleeder and pump the clutch. Do the same thing to for the brakes but make sure you use the bleeder on the front left caliper.
Johnmadsen
Apr 15, 2018 03:16 PM
hawtsoss
Oct 24, 2008 07:21 AM
tek_civic
Jul 13, 2008 11:52 PM
bambam
15
Jun 20, 2005 06:14 AM
976
Sep 17, 2001 05:42 PM
