D16y8 swap into 94 honda covic
Old Jan 19, 2020 | 06:27 PM
Tommy McDonald's Avatar
Default D16y8 swap into 94 honda covic
Ok so i had a 97 coupe with a 5 spd d16y8.. I bought a 94 civic with a blown motor and automatic.. Im wanting to swap the d16y8 and 5spd tranny into the 94 any tips to help or anything that ill need to do
Old Jan 20, 2020 | 09:04 PM
eHMxhACk's Avatar
yippee-ki-yay
10 Year Member
Default Re: D16y8 swap into 94 honda covic
Start here: https://honda-tech.com/forums/honda-...tions-1998336/
There’s a ton of information.
eH.
Old Jan 21, 2020 | 04:05 PM
Thanks
Old Jan 21, 2020 | 05:06 PM
mk378's Avatar
The engine is practically a direct bolt-in.
The auto to manual swap though is going to require a bunch of parts from a generation 5 (1992-1995) manual Civic. Most likely including the transmission since I think the mount on the right side is different in the generation 6.
Old Jan 21, 2020 | 05:16 PM
Do you xactly what ill need?
Old Jan 21, 2020 | 05:32 PM
NVturbo's Avatar
O.G. triple O.G.
you will definitely need an aftermarket mount at the tranny...Hasport, Innovative, etc.
As for other stuff, they mostly will bolt up with the exception of the ECU. You will need a P28 (OBD1) ecu. Engine wiring harness, that will be a fun venture. Hopefully you're mechanically inclined. If not, GOOD LUCK...
Old Jan 21, 2020 | 05:36 PM
Im a diesel mechanic... So i cant use the ecu and harness from the 97.
Old Jan 21, 2020 | 07:15 PM
laylow's Avatar
This thread will guide you, good luck.
https://www.clubcivic.com/forum/thre...t-list.157624/
gnxpro24
Northeast (Sales)
Aug 27, 2014 05:43 PM
civicb16eg
Aug 23, 2007 08:46 PM
xtremecivichb
Jun 17, 2003 09:06 PM
Gcar
Dec 21, 2002 06:06 PM
