Starter solenoid
Old Jan 19, 2020 | 10:47 AM
Christian Jones's Avatar
Default Starter solenoid
Starter relay wire not getting power I checked fuses and everything look good I have good connections from battery can jump start car with with wire by touching the battery and solenoid but when I turn the key switch nothing happen
Old Jan 19, 2020 | 12:27 PM
California98Civ's Avatar
Default Re: Starter solenoid
You checked clutch or brake safety switch? Key switch too?
Old Jan 19, 2020 | 03:59 PM
it automatic and the key switch good I just replaced it not to long ago
Old Jan 19, 2020 | 04:36 PM
muellersfan's Avatar
Not sure what relay you tested for voltage because the auto trans does NOT have a starter relay.
What car do you have?
Old Jan 19, 2020 | 07:44 PM
my bad I mean the starter solenoid wire and it a 00 civic dx
Old Jan 19, 2020 | 08:38 PM
The gray connector C433 below the center console sends voltage from the ignition switch to the A/T gear position switch. Unplug the C433. Check whether pin 10 (Blk/Wht wire) of the male-side connector has battery voltage with the key held in the ON(III) START position.
Darrell Woods
Sep 7, 2018 06:09 AM
tvdc2
Audio / Security / Video
Jul 29, 2016 11:13 AM
apm
10
Mar 30, 2013 08:57 PM
cruz_96LS
Jul 27, 2010 03:44 AM
