Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
05 Honda Civic Ex removing fuel rail
Old Jan 19, 2020 | 01:02 AM
Tyler Parker's Avatar
Default 05 Honda Civic Ex removing fuel rail
I need some help with removing the fuel rail I have everything apart down to the fuel rail but for some reason I cant get it off I have both hoses unclamped both the bolts I saw can someone give me a step by step for this model it would be much appreciated
Old Jan 19, 2020 | 09:18 PM
Asusfang's Avatar
Default Re: 05 Honda Civic Ex removing fuel rail
If you have gotten the fuel rail torn all the way down and disconnected the hoses i'm sure you have undone the bolts that hold the fuel rail in at this point you'll want to use something and lightly pry or pull on the rail. The O rings are probably just really holding them in tight.
worst case the rail will be disconnected from injectors. Just be gentle and it should turn out fine.
-A
Redemption
Free Stuff
Feb 13, 2009 11:47 AM
HpRevolution
May 23, 2007 09:42 AM
BOOSTED_JDM_DB8
May 15, 2006 06:49 PM
turboxsi
Sep 21, 2003 09:48 AM
