comp cam springs reliable?
Old Jan 18, 2020 | 11:19 AM
JASC's Avatar
5 Year Member
Default comp cam springs reliable?
Hi guys, I'm doing a B16 N/A build. I have comp cams 57200(stage 2 cams), that came with their B-series springs. I'll be using skunk2 ti retainers with the set, but my question is ,if anyone knows how reliable the springs are. I know they aren't popular, but if I dont need to buy new springs I'll work with them. Thanks
Old Jan 18, 2020 | 08:26 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: comp cam springs reliable?
It is safer and typically more reliable to use springs and retainers from the same manufacturer because they are DESIGNED to fit with each other. I would recommend you examine the contour of the Skunk2 retainers carefully and compare those measurements to the inner and outer Comp springs.
Old Jan 19, 2020 | 02:48 AM
JASC's Avatar
5 Year Member
I'll definitely do that this morning. Thanks
Old Jan 19, 2020 | 03:20 AM
JASC's Avatar
5 Year Member
Comp cam springs Inner 23mm outer 30mm. Skunk2 retainers inner 22.5 and outer 27mm. Looks like it will work out fine.
TeggieeTuner
Apr 27, 2012 06:37 PM
tales sol
21
Feb 7, 2012 11:22 AM
imnike9000
11
Nov 22, 2009 06:33 AM
ayos ctr_hatch
Apr 24, 2009 04:16 PM
smkngsr
Sep 16, 2005 09:38 AM
