D16 Turbo Partout: Sheepey, Tial, Holset, Eagle, Wiseco, Rocket, etc.
Old Jan 17, 2020 | 08:07 AM
Alex Trebek's Avatar
Default D16 Turbo Partout: Sheepey, Tial, Holset, Eagle, Wiseco, Rocket, etc.
Parting out my turbo D16. Ideally I'd keep it all together, but I'll consider splitting it up there is enough interest in all the parts. Everything works great. Just needs a little cleaning. I didn't have time to give everything a good scrub, but it's all in fine working order. I'm in Metro Detroit for local pickup. I'll ship everything. All prices are OBO, not including shipping costs. I'll include a price for everything that is "fitted" as a package for a 96-00 Civic Coupe. Of course you'll need to make provisions on your car to mount the IC and everything.
Price for: Turbo manifold, turbo, wastegates, intercooler, IC piping with BOV, and Intake manifold $1800
Turbo: Holset HX35 7 blade, rebuilt by Boost Lab with about 1000 street miles on it. It has the stock hardline for a train that goes to braided stainless. 12cm^2 exhaust with WG welded shut. This is the smallest divided housing you can get. It has a 3" v-band welded to it for the outlet. $300
Manifold: Sheepey divided with T3 flange. $900
Wastegates: Two Tial MVS 38mm gates, rebuilt by Tial with about 1000 street miles on them. Dumps are not stainless (as you can see) made by me, and come with the gates if you want them. $240 each, $430 for both.
Boost Controller: Turbo XS MBC $50
The intercooler is a speedfactory core with custom end tanks. Pressure tested to 50psi, no leaks. $300
IC piping: Matches with the rest of the kit, knockoff Greddy Type RS BOV, this is the only piece needed for the whole kit. 2.5" all the way. $100
Cam: Rocket Motorsports D16Z6 Stage 5, but ground by Rocket so you don't need to ground out the cam tubs on your cylinder head. $450
Pistons: Wiseco 75.5mm pistons $300
Rods: Eagle H beams $200
Flywheel: Competition Clutch D2B flywheel. That's a D series crank pattern but takes a B series input shaft and clutches. $120
Clutch: Competition Clutch Stage 4 Sprung Kit, including bolts and TOB $180
Intake Manifold: Skunk 2. Comes with an IACV, stock D16 TB with FITV. There is a broken off IAT sensor that I never bothered to remove all the way, it never leaked or gave me any problems. I just used the sensor in my IC piping. $150
MAP sensor: Omni 4 bar for D/B/F/H $60
There is a lot going on, so ask any questions if something is unclear. First come, first served. If you want the fastest back and forth, include your phone number in any PM's.
Thanks for looking!
Old Jan 23, 2020 | 03:49 PM
Default Re: D16 Turbo Partout: Sheepey, Tial, Holset, Eagle, Wiseco, Rocket, etc.
MAP sensor sold.
NeonPinHead
Mar 31, 2015 12:20 PM
Louis53123
Mar 6, 2008 10:36 AM
