Turn signal issue
Old Jan 14, 2020 | 05:23 PM
knightspeed's Avatar
Default Turn signal issue
So I have a weird issue with my left turn signal. When I turn on the left turn signal the rear signal flashes fast and bright which is what I want because I changed the rear turn signal bulb with an LED. The front left signal flashes fast as well but it's dim. The front left turn signal has the OEM bulb. Another issue i'm having is when I turn on the headlights the left turn signal stays on without flashing and without me engaging the signal. The right signal works normally, the front and rear flash fast and bright and it's the same set up as the left side. Any ideas as to what the issue could be? If it matters, my OEM wires for my headlights are cut. No wires were cut or modified to the turn signals.
Old Jan 14, 2020 | 06:04 PM
muellersfan's Avatar
Default Re: Turn signal issue
Car?
Old Jan 14, 2020 | 06:09 PM
Originally Posted by muellersfan
Car?
Damn...sorry it's been a long day. 99 Civic coupe Si
Old Jan 14, 2020 | 06:28 PM
The left front headlight and turn signal share a common ground in the engine bay (G202). Wire brush clean and tighten the G202 ground connection.
Old Jan 14, 2020 | 06:45 PM
interesting.....I'll try that. Thanks for the quick reply.
Mister_1
Honda Civic (2006 - 2015)
Jun 5, 2018 05:36 PM
superfly23
Honda CR-V & Element
Feb 22, 2016 01:00 PM
jdm_ek_noob
12
Dec 22, 2014 09:09 PM
kr0n1c
Apr 15, 2011 03:34 PM
LuderCriS
Feb 20, 2002 02:50 PM
