Obd2a into obd2b
Ok so I bought a wrecked 98 civic with the d16y8 obd2a going to rob the head for my 2000 civic obd2b got it on there ran in to the distributor issue what else should I expect???
When I bought the car it didnt have anything but the stripped head and the head gasket was blown so I just threw my head on it that had the intake manifold and distributor. The car is a ex and it still has the stock ecu. The head is off of a 98 civic ex which if I'm correct is obd2a. The 00 is obd2b the issue is the plug not matching up so I know I have to wire in the plug off of the 98 ex. I found the diagram to do so. I was just curious if there would be anything else I would run into so I can hopefully have it going tomorrow to have a way back and forth to collage my ef blew up a few days ago.
Ok wired in the old distributor plug on the obd2b harness she is running and reall down and dirt nasty it's a 2000 civic coupe ex hastings rings hastings bearing upgraded wrist pins and PC p29 pistons with a compression ratio of 12.5:1 the only issue is its surging and I'm clueless ik it's the iac valve but dont know how to convert it
autocrossCRX44
Oct 10, 2017 07:55 PM
naedeloc
Apr 1, 2010 05:49 PM
JoshM3357
Jan 13, 2009 05:36 AM
