Denso 2840 Radiator Identification
Old Jan 13, 2020 | 06:29 PM
cryptodolphin's Avatar
Default Denso 2840 Radiator Identification
wondering if someone could help me out identifying
this radiator as I cannot find it anywhere. I see a bunch of half-size aluminum ones but none that are painted black. Any help would be appreciated.
Old Jan 14, 2020 | 08:24 AM
NVturbo's Avatar
O.G. triple O.G.
Default Re: Denso 2840 Radiator Identification
I've never seen a stock radiator painted black from the factory. Either it's NOS (new old stock) or Chinese knockoff.
Old Jan 14, 2020 | 09:26 AM
stin1's Avatar
Loved
Community Favorite
I am skeptical here on this radiator. First the part number doesn’t seem to exist. The white letters are inconsistent with any radiators I have. They have more of spotted paint than the bold thick font in the above example. I also agree with the above statement they shouldn’t be painted. I also don’t recall these radiators being available as an assembly with the fan . The decal is an old decal and seems to lack country of origin. I am guessing maybe it’s a rebuilt radiator with a replacement fan based on the mid tank still retaining the Honda stamp . The rebuilder may have created his own part numbers. The right corner seems bulgy on the tank compared to my examples on a further note.
Old Jan 14, 2020 | 12:26 PM
Thank you for the information, I found this with a bunch of other OEM parts that had the same labels and such. Do you happen to know what model it might be for based on the looks? Best I could find was similar to a 94 Integra
Old Jan 14, 2020 | 12:30 PM
Thank you for your help and information on this. This is another one I have that has the same type label, but on this one they numbers seem to match.
Old Jan 14, 2020 | 12:31 PM
NVturbo's Avatar
O.G. triple O.G.
That's definitely a knock-off, especially the radiator cap. The "ND" stamp is not refined...along with the decal. Here is a Genuine Honda cap. Notice the writing in German is only one line....
OP, if you aren't planning to boost the engine, a replacement one from your local auto parts store should be fine.
Old Jan 14, 2020 | 12:43 PM
Are you sure it might not just be an old OEM cap? I dont understand why someone would go out of their way to do all this since it seems like there would not be too much money to be made. Thank you for your help and information!
Old Jan 14, 2020 | 12:48 PM
I suppose that you are correct about the cap being a knockoff, the only other ones I found are questionable like "OEM authentic" from Amazon....we know how authentic it would be from there.
Old Jan 14, 2020 | 01:01 PM
NVturbo's Avatar
O.G. triple O.G.
There are countless "OEM" style caps out there. You just have to make sure it's actually a genuine one from Honda/Denso. It may not seem much but the cheap knockoff caps do not hold pressure and will cause heating issues. If you want a good radiator cap, go with one from Stant. They have the "racing" version and it holds higher pressure than most others. That's what I'm currently using in mine...
Old Sep 8, 2020 | 09:18 AM
94eg!'s Avatar
#1 Super Guy
Loved
This looks to be the older copper core denso used on a 92-95 Civic with a d-series (single core) and automatic transmission. The glossy black paint and markings match perfectly to the OEM denso I bought a few years ago for my CRX (straight from the dealer). You can tell it's copper by the weight and looking between the fins and seeing the brown color inside. In 96 Honda switched to aluminum cores on these half radiators.
The really interesting part about this one is that it includes a fan and shroud. Probably why the part number is unique and doesn't show up anywhere.
Herbie
Nov 6, 2006 02:38 PM
Dartanian
Jun 13, 2006 09:37 PM
petrv
Apr 27, 2004 09:29 AM
MachAF
Aug 2, 2003 10:17 PM
Woody_geeser
Sep 25, 2001 03:02 PM
