Oem B16 Valve Guide Part #’s
Im in need of new valve guides for my b16a head, its a turbo motor making around 450. Its going to be a street car so im deciding to go with the steel guide instead of bronze. I need to part numbers for the exhaust and intake side if anybody knows them!! In having trouble finding them online.
You won't find them online, nor through dealers. you may nee to go to the machine shop that you plan on having install the guides special process) and ask them accordingly. I use steel guides also, and have only had them replaced individually through the machine shop. Honda doesn't seem to have a part number for the guides themselves.
Good luck to you..
Good luck to you..
The factory guides are currently available through your Honda/Acura Dealership Parts Department.
Intake guide: 12204-PR3-305
Exhaust guide: 12205-PR3-305
Thanks for the advice! I was looking into bronze valve guides aswell, would i be okay with running bronze? Its a weekend turbo car. I hear a lot of things about them wearing out crazy fast.
Good luck to you..
Good luck to you..
